Clouds Render Order
I have some troubles with a Cloud Layer Object.
It doesnt render in the background, instead over my objects.
What can I do in terms of order?
Thank you.
Werner
Ja, that has no effect.
Funny, that in a previous version of our scene, the clouds appear correctly. So I need to investigate that phenomenon.
I found out, that the position (z) has something to do with that.
The couds seems to take that value into consideration somehow.
At 0 its completely on top of other objects.
The higher the value, the further the clouds move into the background.
Funny Bunny.... Bug??
Hi Werner,
I believe that lowest possible cloud layer should be located at least with Z = 100m. If you can send us a test scene we can take a look into it and see what else we can do here.
Ah. Na its alright.
100 as minimum is fine here as well.
I was just wondering about this behavior.
Cheers.
Werner
