[SOLVED] Saving joystick inputs in controls
I am trying to use the Unigine input system (with SDK 2.0-beta2). I managed to display the Unigine::Input::ControlSetupWindow in my project and save keyboard and mouse inputs in the XML control file I created.
My problem is, I failed saving joystick inputs. I have an XBox 360 gamepad which is correctly recognized : I made a debug widget which displays the status of the pad to make sure of that. I have been diging in the scripts\input folder to try to understand the problem : I saw that the inputs of the pad are correctly registered in the device manager, but it seems their status is not updated there and I don't understand why. I guess I am missing something and I would appreciate any help.
Another little question : when I click on my status widget (or anywhere outside the game area), the pad becomes "unavailable". Is there a way to fix that ?
Thanks !
Great, Maxim ! I tried it and it almost works : axis and buttons of the controller are recognized, but not the d-pad. There is also a bug with the buttons : if I bind one to an action with the ControlSetupWindow, the next time I try to bind a control, the input dialog acts as if the button is still pressed even if it's not.
Thanks again !
Hi, Jonathan!
Use attached input.patch to fix this. And use ControlsXPad360 instead of ControlsJoystick for xbox 360 pad in CInputManager. If you will have "cannot load xinput1_4.dll" use ControlsXPad360.cpp.patch.
Unigine.zip
  • 2 weeks later...
Hi Maxim, sorry I did not reply sooner, I had to work on another project for a while.
It seems the input.patch file you sent is the same as the last time. I had already applied it, then created a new project with the modified SDK and then copied my code in it (I don't know if it's the best way to do it). The pad was detected in the ControlSetupWindow unlike before, but then there were the other bugs.
Today, I tried it with another controller, a Logitech G25 racing wheel. Its d-pad is recognized, but there is the same bug with the input dialog, where the last button pressed when defining an action is still detected as pressed when defining another action.
Hi Maxim,
It seems to work perfectly with the XPad, good job !
There's still a little issue with the G25, I didn't see it before : when trying to enter an input for an action, the pedals are immediately detected. This is because they are not regular joystick axis, regarding their range and their neutral value. I had no luck trying to fix this so far but I'll keep you posted if I find a solution.
Thanks again.
I made a special case for the pedals in InputDialog::init_inputs() : they only get a "negative" Input where the other axis have a positive and a negative Input. I'm not sure it's the best solution but it works for now !
For the record, I had another problem when I tried to get the state of the actions (in Unigine::Input::Control::actions). The states wouldn't change when using the inputs bound to the actions.
It turned out I always ended in a case which forced the state to be neutral. In the getState() function of the Unigine::Input::Action class, there is this :
if(def.lockable && (engine.gui.getActivity() == 1 || engine.app.getMouseGrab() == 0))
	return getNeutral();
I didn't really understand why this test was always true for me, but I commented this part so I could move forward.
Then I could get the states of the actions bound to a mouse or keyboard input, but not to a joystick input. I finally realized this was the same issue as in the input dialog, which you corrected with the patches : the input devices were not updated. So in the update() function of the Unigine::Input::Input class, I added this (after the first test on input_device)  :
	input_device.update();
Now everything seems to work !
Hi, Jonathan,
Thank you for helping us finding bugs! In getState function must be:
if(def.lockable && (engine.gui.getActivity() == 0 || engine.app.getMouseGrab() == 0))
And instead of calling input_device.update() in Unigine::Input::Input::update() better call Unigine::Input::update in world script update function.
