renato.semadeni Posted November 14, 2014 Share Posted November 14, 2014 Hi there I created a landscape and applied a diffuse texture. If I apply a more detailed texture to the Refined parts, it gets mirrored a long the y (or x?) axis. In the attached picture, I used the same texture for the coarse and the diffuse texture. And as you can see the artefact in the data is mirrored. thanks in advance Renato Link to comment
silent Posted November 14, 2014 Share Posted November 14, 2014 Hi Renato, Could you please send your terrain to us? This behavior can be reproduced only in Unigine 2.0? Also, our team is now focused on landscape and terrain improvements, so we can check this behavior on our internal builds. Thank you! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
renato.semadeni Posted November 14, 2014 Author Share Posted November 14, 2014 Hi Silent I haven't tried it out with Unigine 1.0. I can reproduce the effect with every texture (tried only .png). So I didn't sent you a texture. Hope this is okay with you.. https://www.dropbox.com/s/0buqla72q5z7n5y/landscape.zip?dl=0 I will try it with the previous version of Unigine. Thanks a lot Link to comment
silent Posted November 14, 2014 Share Posted November 14, 2014 Thank you! Will check this ASAP (but only next week, I'm afraid). How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
silent Posted November 17, 2014 Share Posted November 17, 2014 Hi Renato, This issue is already fixed in our internal builds. Landscape plugin should generate valid terrains in the next SDK update (release planned at the end of this week). However, it is not recommended to manually adding every texture on Refined Tab (that's why you get that flipped images). Sorry for the inconvenience caused. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
renato.semadeni Posted November 18, 2014 Author Share Posted November 18, 2014 Hi Silent Thanks a lot. But, how would you recommend to add the textures to the refined tab? kind regards, Renato Link to comment
silent Posted November 18, 2014 Share Posted November 18, 2014 Landscape plugin should import refined textures (with respect of Flip Y option). This step is not working properly in current alpha version. I would recommend to wait the next SDK version. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
