hosein.dophlin Posted January 7, 2011 Share Posted January 7, 2011 Hi all I am a newer user in this forum, and i design shaders for games, i want to use my special shader in Unigine, i wrote that in HLSL format. How can i import fx file in Unigine? Thanks Link to comment
ulf.schroeter Posted January 7, 2011 Share Posted January 7, 2011 How can i import fx file in Unigine? there is no easy import of an fx file as UNIGINE uses a different shader concept. Have a look into documentation "Content Creation\Materials Overview\How to Create a New Material" for more infos. You will find UNIGINE material definitions in subdirectory data/core/materials and shaders in data/core/shaders 1 Link to comment
hosein.dophlin Posted January 7, 2011 Author Share Posted January 7, 2011 there is no easy import of an fx file as UNIGINE uses a different shader concept. Have a look into documentation "Content Creation\Materials Overview\How to Create a New Material" for more infos. You will find UNIGINE material definitions in subdirectory data/core/materials and shaders in data/core/shaders Thank you ulf.schroeter, i saw a notice on the documentation like this: "Unigine extensions can be divided into three types depending on the interface to be used: //C++ API (components in C++) Material system (shaders in GLSL/HLSL) //Interpreter (scripts in UnigineScript) " so you think i can not use HLSL format in Unigine directly? Link to comment
ulf.schroeter Posted January 8, 2011 Share Posted January 8, 2011 so you think i can not use HLSL format in Unigine directly? As UNIGINE supports different rendering systems (OpenGL, D9/10/11, PS3) each shader definition file actually includes different language versions of the same functionality. /* Copyright (C) 2005-2010, Unigine Corp. All rights reserved. * ..... */ #ifdef OPENGL .... void main() { ... } /******************************************************************************\ * * Direct3D9 * \******************************************************************************/ #elif DIRECT3D9 ... VERTEX_OUT main(VERTEX_IN IN) { ... } /******************************************************************************\ * * Direct3D10/Direct3D11 * \******************************************************************************/ #elif DIRECT3D10 || DIRECT3D11 ... VERTEX_OUT main(VERTEX_IN IN) { ... } /******************************************************************************\ * * PlayStation3 * \******************************************************************************/ #elif PLAYSTATION3 ... VERTEX_OUT main(VERTEX_IN IN) { ... } #endif For DirectX9/10/11 HLSL format is used, so you can put your existing HLSL code into the DX #ifdef sections. If you also want to support OpenGL/PS3 you have to provide also shader code versions in GLSL/PS3 dialect. 1 Link to comment
