alexei.garbuzenko Posted August 20, 2010 Share Posted August 20, 2010 Is it possible to use mip-maps with .PNG/.JPG/.TGA textures? For example, I got 512x512 texture that weights about 44kb in .PNG format and converting it to DXT1-DXT5 ruins the quality while RGBA8 texture with mipmaps weights about 1.4Mb.. Link to comment
frustum Posted August 21, 2010 Share Posted August 21, 2010 Is it possible to use mip-maps with .PNG/.JPG/.TGA textures? For example, I got 512x512 texture that weights about 44kb in .PNG format and converting it to DXT1-DXT5 ruins the quality while RGBA8 texture with mipmaps weights about 1.4Mb.. Yes, it's possible. But time of png decompression will produce stalls in render. There is another solution: DDS file in rgba8 format with mipmaps. Unigine editor and imagedds.py support following postfixes for automatic texture conversion: "d" : FORMAT_DIFFUSE, "dr" : FORMAT_DIFFUSE_RAW, "d1" : FORMAT_DIFFUSE_DXT1, "d3" : FORMAT_DIFFUSE_DXT3, "d5" : FORMAT_DIFFUSE_DXT5, "s" : FORMAT_SPECULAR, "sr" : FORMAT_SPECULAR_RAW, "s1" : FORMAT_SPECULAR_DXT1, "s3" : FORMAT_SPECULAR_DXT3, "s5" : FORMAT_SPECULAR_DXT5, "n" : FORMAT_NORMAL, "nr" : FORMAT_NORMAL_RAW, "p" : FORMAT_PARALLAX, "pr" : FORMAT_PARALLAX_RAW, "h" : FORMAT_HEIGHT, "hr" : FORMAT_HEIGHT_RAW, "t" : FORMAT_TESSELLATION, "tr" : FORMAT_TESSELLATION_RAW, "a" : FORMAT_AMBIENT, "ar" : FORMAT_AMBIENT_RAW, "e" : FORMAT_EMISSION, "er" : FORMAT_EMISSION_RAW, "l" : FORMAT_LIGHTMAP, "lr" : FORMAT_LIGHTMAP_RAW, RAW format is an unmodified format of source image. Link to comment
alexei.garbuzenko Posted August 21, 2010 Author Share Posted August 21, 2010 You said it is possible, but how? In Image.cpp/load_png() I see only calls to create2D(...,...,...,1,0) meaning that only one mipmap is loaded from PNG image. Do you mean that mip-maps could be created on scripts side by using Image class? That not sounds as a solution for me.. It would be even better to re-compress PNGs to RGBA8 DDS in installer or on the first run. Link to comment
frustum Posted August 21, 2010 Share Posted August 21, 2010 You said it is possible, but how? In Image.cpp/load_png() I see only calls to create2D(...,...,...,1,0) meaning that only one mipmap is loaded from PNG image. Do you mean that mip-maps could be created on scripts side by using Image class? That not sounds as a solution for me.. It would be even better to re-compress PNGs to RGBA8 DDS in installer or on the first run. source/engine/render/RenderManager.cpp 410 line: if(image.getNumMipmaps() == 1 && (flags & (Texture::FILTER_BILINEAR | Texture::FILTER_TRILINEAR))) { flags = (flags & ~Texture::FILTER_MASK) | Texture::FILTER_LINEAR; } Mipmaps will be generated automatically by texture class if you comment this code. Link to comment
alexei.garbuzenko Posted August 21, 2010 Author Share Posted August 21, 2010 Okay, thank you! P.S. I vote to put an option "auto generate mipmaps" to global config file to avoid unnecessary code intrusion. Link to comment
