werner.poetzelberger Posted March 18, 2013 Share Posted March 18, 2013 Hello. Setting a cubemap as env. reflection. is easy. Is there also an easy way, to set a dynamic cube map, which is rendered from the scene, as the env. map? (I also think, that some more parameters need to be animated when it comes to the day/night cycle. But this q. just as a beginner`s q.) Best. Werner Link to comment
danni.coy Posted March 18, 2013 Share Posted March 18, 2013 There is a system called Tracker that allows you to animate a day and night cycle including blending between environments. The Valley demo is probably the best example of this system in use. dynamic cubemaps specifically for reflections is possible. Link to comment
werner.poetzelberger Posted March 19, 2013 Author Share Posted March 19, 2013 Hello Danni, The Tracker, right. I saw some of the demos animated values. Valley Demo. Ok. I think I need to take a look at that. Thank you! werner Link to comment
