rohit.gonsalves_ Posted November 16, 2010 Share Posted November 16, 2010 Hello, Please see the two points of problem 1] In the documentation there is description for lightMix, But it is not coming. I guess it is removed. Is it true? 2] When lightmaps are used through ambient pass they are rendered correctly in the preview but no in the actual rendering. It shows black. Please check the attached world for the same. Please change the file extension from .txt to .7z and check the problem. Are doing anything wrong? LightMapTest.txt Link to comment
rohit.gonsalves_ Posted November 18, 2010 Author Share Posted November 18, 2010 Will anyone say something about this issue...? Link to comment
manguste Posted November 19, 2010 Share Posted November 19, 2010 1] In the documentation there is description for lightMix, But it is not coming. I guess it is removed. Is it true? Yes, it was removed because nobody used it. Do you? 2] When lightmaps are used through ambient pass they are rendered correctly in the preview but no in the actual rendering. It shows black. The problem is fixed and you can get it working in the next update. Link to comment
rohit.gonsalves_ Posted November 20, 2010 Author Share Posted November 20, 2010 Yes, it was removed because nobody used it. Do you? The problem is fixed and you can get it working in the next update. Thanks for the reply, We don't use it. But content developer got confused as it was there in documentation and not in the build. Please update the docs... We will wait for the next update. Thanks. Link to comment
frustum Posted November 23, 2010 Share Posted November 23, 2010 I have added sample with lightmaps: samples/lights/lightmap_00. You can get it in next update. Link to comment
