demostenes Posted February 9, 2013 Share Posted February 9, 2013 Generally I have no problem with using alfa test, or alfa blend settings. But in this case, this feature does not work at all and I am out of ideas, what I am doing wrong. For example banner with alfa test works. Also unigine sees my water texture OK. But in the scene there is no transparency with alfa test and very very weak transparency with alfa blend (src alfa, one minus src alfa). What I am I doing wrong? Thanks. Link to comment
demostenes Posted February 9, 2013 Author Share Posted February 9, 2013 Hmm, I found the cause. Alfa test/blend works only with 100% black, not for example 99%. Which is interesting, because texture preview in material editor works in both cases. Of course drawback is, that i have very little control over the blending (nothing in between). Link to comment
manguste Posted February 22, 2013 Share Posted February 22, 2013 Jiri, That's actually not the expected behaviour. Alfa test/blend works by a 50% threshold. Can you share a texture so we can test on our side? Link to comment
demostenes Posted March 2, 2013 Author Share Posted March 2, 2013 Jiri, That's actually not the expected behaviour. Alfa test/blend works by a 50% threshold. Can you share a texture so we can test on our side? I had the source texture in tif, so I tried to convert it to psd (i think i was using png before) and then with unigine dds converter and it behaves far better (but IMHO still not perfect). Anyway I uploaded it to your ftp as waterfall1.tif Link to comment
silent Posted March 5, 2013 Share Posted March 5, 2013 demostenes, We've tested your *.tif file and could not reproduce your issue. When exported to 32-bit *.tga (with alpha-channel), *.psd or *.dds (via imagedds tool) formats, alpha-testing is working fine. Could you describe in more detail what is troubling you? How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
