[SOLVED] Minimising frame drop with App Wall
I am using app wall to run 3 screens using three graphics cards.
I am getting a serious framerate drop using the appwall setup as opposed to running a large buffer accross all three screens.
Any suggestions on where I might look to get better performance?
AppWall performs three scene renders with three independent projection/modelview matrices.
AppSurround performs only one scene render with single projection/modelview matrix.
You can use AppSurround if you don't need three independent projections.
We do need independent projections....
I have a partial solution however. I naively thought since I was running 3 windows on 3 screens that the computer that I would get a card running each window.
Setting the computer up for Trifire seems to have aleviated our problems somewhat - updating to the latest version of the drivers also helped
If possible, it also makes sense in your case to render each 3-monitor configuration via AppSurround. For example:
can be rendered as 3 x AppSurround.
 The screen configuration is now 7 screens with 30 degrees between each screen. Trifire is making things workable at the moment  but still open to other suggestions.
