wxywxy.ji Posted December 20, 2012 Share Posted December 20, 2012 when i make portal do I need to shorten the distance between worldsector and worldsector? i made shorten the distance player is culled. only solve way that player's part node attr is changed spatial? Link to comment
manguste Posted December 20, 2012 Share Posted December 20, 2012 The distance between 2 WorldSector nodes should be as small as possible. (shortening it was a good thing to do; otherwise, there can be artefacts when doing scissoring test for lights). If you players are culled, disable Nodes panel->Node->Spatial flag. It means, sectors and portals do not control the visibility of a node (the node is excluded from sectors and is always visible). Link to comment
