danni.coy Posted August 16, 2012 Share Posted August 16, 2012 I have material with the auxiliary pass set to default. I have an auxiliary colour defined in the material. I can see this colour in a buffer when I press 5. How do I get it this to overlay my mesh in the main veiwport? [edit] solved one has to 1) make sure that auxilary is enabled in render settings (esc key menu). 2) create a child material of render_composite. set the auxilary to overlay. 3) use the render settings to add that material as the composite shader. Link to comment
manguste Posted August 16, 2012 Share Posted August 16, 2012 I've added cross-links into docs to make this more transparent. Link to comment
