Rob Posted February 27, 2012 Share Posted February 27, 2012 I got a mesh in my scene, a large tunnel with only 500 polygons with 2 UV sets Whenever I try to generate a lightmap for it the editor freezes and my cpu goes to 100%, I left it running for 30 minutes but it was still stuck It freezes as soon as I press Create lightmaps I only got 2 lights in my scene a spotlight and a sunlight, does anyone know what could be wrong? Am I using the wrong lights? **Edit:** For some reason the lightprob number is really high, I already tried delting the lights and added only 1 single spotlight but the number stays high Link to comment
frustum Posted February 28, 2012 Share Posted February 28, 2012 Increase the step of LightProb grid to reduce the number of probe lights. Light-mapper generates heap of virtual LightProb sources to simulate global illumination. Moreover you can specify the bounding mesh to remove unnecessary regions. Link to comment
Rob Posted February 28, 2012 Author Share Posted February 28, 2012 Increase the step of LightProb grid to reduce the number of probe lights. Light-mapper generates heap of virtual LightProb sources to simulate global illumination. Moreover you can specify the bounding mesh to remove unnecessary regions. Ok will give this a try Link to comment
