jadav.rakesh Posted November 10, 2011 Share Posted November 10, 2011 Hi guys, I am messing around sound from last few days. If I am not wrong I read somewhere in manual that unigine does support ".wav", ".oga" and ".ogg". I am trying to play ".ogg" sound files but it's not working at all. looks like it's playing or doing something in background but I can't hear any sound, while ".oga" samples are working fine. If ".ogg" is not supported or not working, would you recommend converter which convert known sound formats ( .mp3, .ogg, .wav, etc ) to .oga format which works fine with editor. BTW, I could not attach any .ogg file here bcoz I got message "You aren't permitted to upload this kind of file" ? :) Thanks, rakeshj. Link to comment
binstream Posted November 10, 2011 Share Posted November 10, 2011 .oga is the same .ogg file (Ogg Vorbis format), the only difference is filename extension. Rename your .ogg files to .oga and it will be working. Link to comment
jadav.rakesh Posted November 10, 2011 Author Share Posted November 10, 2011 that's working. Thanks, rakeshj Link to comment
t.coursey Posted August 22, 2018 Share Posted August 22, 2018 I just tried converting my MP3 files to OGA and they are not working. I will try making them OGG files and then renaming. Any other thoughts? 2.7.2.1 Link to comment
vvvaseckiy Posted August 23, 2018 Share Posted August 23, 2018 Hello @t.coursey, Could you please clarify the specifications of the file you are using. If it's possible, sample would be great. Also in 2.7.2.1 you no longer need to rename .ogg files, engine works both with .ogg and .oga extensions. Thank you! Link to comment
t.coursey Posted August 23, 2018 Share Posted August 23, 2018 9 hours ago, vvvaseckiy said: Hello @t.coursey, Could you please clarify the specifications of the file you are using. If it's possible, sample would be great. Also in 2.7.2.1 you no longer need to rename .ogg files, engine works both with .ogg and .oga extensions. Thank you! @vvvaseckiy I have it working now. Not sure what it was... I did make sure the new files are Mono as I heard from Morbid that the attenuation does not work with Stereo files. I may have been seeing something with that. Thanks! Link to comment
