trouble3524 Posted October 28, 2011 Share Posted October 28, 2011 I used static_cast<ObjectMesh*>(ObjectMesh::createNode(Node::OBJECT_MESH)) to create a ObjectMesh. but I didn't found any function to load mesh,except the constructor: ObjectMesh::ObjectMesh(const char *name). It is means if I used Node::createNode to create a Node,I can NOT use the constructor's param; so,how to load mesh??? Thank you. Link to comment
frustum Posted October 28, 2011 Share Posted October 28, 2011 Use ObjectMesh constructor: ObjectMesh *mesh = new ObjectMesh(name); Node::createNode() function is used for world loading and deserializing only. I don't recommend to use engine internal functions. Link to comment
trouble3524 Posted October 28, 2011 Author Share Posted October 28, 2011 Use ObjectMesh constructor: ObjectMesh *mesh = new ObjectMesh(name); Node::createNode() function is used for world loading and deserializing only. I don't recommend to use engine internal functions. It will is take a new problem,I creating a game tool under Qt. Unigine source overloaded "new" in global space, It's didn't work with Qt. So I closed USE_MEMORY define. so,If I use "new Object",I will take a memory problem. If I use Node::createNode function,this problem is not exist. many days ago,I found this solution in this formus.So,I learn to use Node::createNode. Link to comment
frustum Posted October 28, 2011 Share Posted October 28, 2011 Try in-place new constructor: void *ptr = Memory::allocate(sizeof(ObjectMesh)); ObjectMesh *mesh = new(ptr) ObjectMesh(name); And manual destructor: mesh->~ObjectMesh(); Memory::deallocate(mesh); Link to comment
trouble3524 Posted October 28, 2011 Author Share Posted October 28, 2011 Try in-place new constructor: void *ptr = Memory::allocate(sizeof(ObjectMesh)); ObjectMesh *mesh = new(ptr) ObjectMesh(name); And manual destructor: mesh->~ObjectMesh(); Memory::deallocate(mesh); Thank you very much,I will try it. Link to comment
