Graphic glitches in VFX Addon
Go to solution Solved by toxiccrack,
I'm new to the engine and just downloaded the VFX Addon from the asset store. In some examples are graphical glitches, like in the vfx_explosion_2 (see screenshot). I use Unigine 2.18 Community with Linux.
Do i miss something or is this a bug?
Kind regards,
Daniel
  • Solution
I've found the problem.
UnigineVFX/vfx/textures/fire_glow_dr.png
wasn't imported correctly.
Hello toxiccrack,
Could you please provide more information about the PC configuration where you're experiencing this issue? Specifically, could you mention the GPU model and driver version? Additionally, could you describe how you identified the malfunctioning texture? Were there any errors or warnings during the addon import stage?
it's a Linux Machine with an NVIDIA RTX 4070, driver version 535.183.01. I simply deactivated nodes in the editor to see what node it is and then i looked which texture the node used, because it looked like a faulty texture somewhere. Unfortunately, i haven't spend much attention to errors or messages during import.
