sergey.shandar Posted October 11, 2011 Share Posted October 11, 2011 Hi Is it possible to use dynamic lighting for GUI components such as Widget Label? More specific, I need write text on objects. The problem with Widget Label is when I disable all light sources, I still can see the text on labels. Any idea? Link to comment
ulf.schroeter Posted October 11, 2011 Share Posted October 11, 2011 there is no dynamic lighting for GUI objects. For achieving your effect you could use a script function called each frame for monitoring the current state of all your light objects and - based on the result - enable/disable or even fade in/out via blending all your WidgetLabel objects used for object text 1 Link to comment
Guest shane.ploenges Posted October 11, 2011 Share Posted October 11, 2011 Is this the same case for decals? can decals be affected by environment lighting - they seem not to be in the demo scenes. Link to comment
Guest shane.ploenges Posted October 12, 2011 Share Posted October 12, 2011 I found that the Decal_Base material can do this, but the Demo scenes use an Inherited material that does not - so answer is yes, decal_base works 1 Link to comment
manguste Posted October 12, 2011 Share Posted October 12, 2011 2D GUI elements are designed to be always visible; they are rendered the last, after all light passes. If you do not wish to see them in the dark, you need to disable them manually. Decals are affected both by the environment lighting and ambient color. In the decals demo they are not affected by the ambient color, because they are rendered as Materials->States->Ambient->Transparent (in this case only the material color is used). When Ambient pass is set to Opacity, it works fine. 1 Link to comment
