kgregor Posted April 26 Share Posted April 26 (edited) I have windows operating system running with display resolution of 3840x2160 . When I run my unigine project .exe and choose 1920x1080 from list of options, render area is shrinked to smaller size. I use "Fullscreen: enabled" option. Please see attached screenshot. I have NVIDIA GTX 1050 Ti. And if I change windows os display resolution to 1920x1080 and then run my .EXE at same resolution, there is no problem. Edited April 26 by kgregor Link to comment
kgregor Posted April 26 Author Share Posted April 26 I found the problem appears if scale is different than 100 %. I use 150 % and if I change it to 100 % the problem disappears. Link to comment
kgregor Posted April 26 Author Share Posted April 26 I hope the problem appearing at these scales will be solved in near future Link to comment
kgregor Posted April 26 Author Share Posted April 26 I tested next Windows display resolutions and scales: - 3840x2160 with 100 % scaling - no problem - 3840x2160 with 125 % scaling - render area shrinked when running at 1920x1080 setting - 3840x2160 with 150 % scaling - render area shrinked when running at 1920x1080 setting - 2560x1440 with 100 % scaling - no problem - 2560x1440 with 150 % scaling - no problem - 2560x1440 with 175 % scaling - no problem - 2048x1536 with 150 % scaling - no problem - 1920x1080 with 100 % scaling - no problem - 1920x1080 with 150 % scaling - no problem - 1920x1080 with 175 % scaling - no problem 2 Link to comment
bmyagkov Posted April 27 Share Posted April 27 11 hours ago, kgregor said: I tested next Windows display resolutions and scales: - 3840x2160 with 100 % scaling - no problem - 3840x2160 with 125 % scaling - render area shrinked when running at 1920x1080 setting - 3840x2160 with 150 % scaling - render area shrinked when running at 1920x1080 setting - 2560x1440 with 100 % scaling - no problem - 2560x1440 with 150 % scaling - no problem - 2560x1440 with 175 % scaling - no problem - 2048x1536 with 150 % scaling - no problem - 1920x1080 with 100 % scaling - no problem - 1920x1080 with 150 % scaling - no problem - 1920x1080 with 175 % scaling - no problem Hello! Thank you for the effort you've applied! In certain cases such issues may indeed arise when using a system scaling other than 100%. This is a known issue and will be addressed in one of the following releases. We apologize for any inconvenience caused. Thanks! Link to comment
werner.poetzelberger Posted April 29 Share Posted April 29 Windows Desktop Scaling is annoying, indeed. Be sure to use 100% always. Best. Werner Link to comment
