Running unigine project on 3840x2160
I have windows operating system running with display resolution of 3840x2160 .
When I run my unigine project .exe  and choose 1920x1080 from list of options, render area is shrinked to smaller size. I use "Fullscreen:  enabled" option.
Please see attached screenshot. I have NVIDIA GTX 1050 Ti.
And if I change windows os display resolution to 1920x1080 and then run my .EXE at same resolution, there is no problem.
Edited by kgregor
I found the problem appears if scale is different than 100 %. I use 150 % and if I change it to 100 % the problem disappears.
I tested next Windows display resolutions and scales:
- 3840x2160 with 100 % scaling - no problem
- 3840x2160 with 125 % scaling - render area shrinked when running at 1920x1080 setting
- 3840x2160 with 150 % scaling - render area shrinked when running at 1920x1080 setting
- 2560x1440 with 100 % scaling - no problem
- 2560x1440 with 150 % scaling - no problem
- 2560x1440 with 175 % scaling - no problem
- 2048x1536 with 150 % scaling - no problem
- 1920x1080 with 100 % scaling - no problem
- 1920x1080 with 150 % scaling - no problem
- 1920x1080 with 175 % scaling - no problem
  • Like 2
Hello!
Thank you for the effort you've applied! In certain cases such issues may indeed arise when using a system scaling other than 100%. This is a known issue and will be addressed in one of the following releases. We apologize for any inconvenience caused.
Windows Desktop Scaling is annoying, indeed. Be sure to use 100% always.
Best. Werner
