jackool Posted January 12 Share Posted January 12 (edited) Hello By this instructionhttps://developer.unigine.com/ch/docs/2.18/sdk/addons/aircraft/?words=200%2Cbe%2C200lll&autotranslate=zh#highlight,I specified the properties of LandingGears for be-200, but when specifying the properties of LandingGearPart, be-200 did not have the gear_ down_ p3 node specified in the document。Although i has been updated ig_ Config.xml and entity.def in the Host_Emulator ,despite the inability to control the landing gear and engine fire in the component,Do you know why,? jackool best regards Edited January 12 by jackool Link to comment
cash-metall Posted January 15 Share Posted January 15 be200 has no gear_down_p3 node, its just description of settings property with random node. if you have installed aircraft addon, you will have access to '201' be-200 modifyed node where is predefined be-200 node with all settings just look in ig_config in aircraft addon <entity id="201" name="be-200-mod"> <path>UnigineIGAviation/ig_aviation/sample_content/be_200_mod.node</path> you can copy entity type in entities.def or just change id in ig_config from 201 to 200 Link to comment
