GoodGoodStudy Posted January 10 Share Posted January 10 Please make a video of using the wall plugin微信图片_20240110113150.bmp Thanks Link to comment
bmyagkov Posted January 10 Share Posted January 10 36 minutes ago, xxx31326 said: Please make a video of using the wall plugin微信图片_20240110113150.bmp Thanks Hello! There is no dedicated video available related to this but you can refer to the following article as a startup guide: https://developer.unigine.com/en/docs/future/principles/render/output/multi_monitor/appwall/index?rlang=cs Could you also please clarify which version of the SDK you are trying to use? Thanks! Link to comment
GoodGoodStudy Posted January 10 Author Share Posted January 10 Sim2.16.0.1, Error: WallImplement::init() Can' t initialize plugin,Main window is null I am currently encountering problems loading the plugin。 I typed plugin_load Wall into the console panel and the above error occurred Link to comment
bmyagkov Posted January 10 Share Posted January 10 2 minutes ago, xxx31326 said: Sim2.16.0.1, Error: WallImplement::init() Can' t initialize plugin,Main window is null I am currently encountering problems loading the plugin。 I typed plugin_load Wall into the console panel and the above error occurred The Wall plugin isn't meant to be run from the editor. Its startup arguments should be used before launching the application as shown in the attached image. Thanks! Link to comment
GoodGoodStudy Posted January 10 Author Share Posted January 10 So this command works in the build package? Link to comment
GoodGoodStudy Posted January 10 Author Share Posted January 10 666 Run successfully,but I fill in the parameters is{ -width 3 -height 1 -extern_plugin Wall},Why does only one screen appear,And it doesn't match what I saw when I ran it directly. I hope you can answer that millions of thanks Link to comment
GoodGoodStudy Posted January 10 Author Share Posted January 10 only 0x0 this screen,and i have three screen Link to comment
bmyagkov Posted January 10 Share Posted January 10 There must be windows overlapping each other. Please try rearranging them as demonstrated in the attached video. 2024-01-10 13-25-22.mp4 Link to comment
GoodGoodStudy Posted January 10 Author Share Posted January 10 111.mp4 I tried,but realy only one . Link to comment
bmyagkov Posted January 10 Share Posted January 10 6 minutes ago, GoodGoodStudy said: I tried,but realy only one . There is a typo in the word "height" where "hegnt" is used instead. Link to comment
GoodGoodStudy Posted January 10 Author Share Posted January 10 I'm so so so so stupid, But why do I run out of the interface is gray, is this related to the camera Settings, and if I want to achieve this effect in the bag, just keep this setting and pack it directly Link to comment
bmyagkov Posted January 10 Share Posted January 10 13 minutes ago, GoodGoodStudy said: I'm so so so so stupid, But why do I run out of the interface is gray, is this related to the camera Settings, and if I want to achieve this effect in the bag, just keep this setting and pack it directly The scene contains a camera by default which has the Main Player parameter enabled. This parameter defines the image from which camera is displayed when the world is run. Enable this parameter for the camera that you want to control at runtime. Link to comment
GoodGoodStudy Posted January 10 Author Share Posted January 10 I set up a maincamera based on what you said,But it's still running on a gray screen Test.mp4 Link to comment
bmyagkov Posted January 10 Share Posted January 10 5 minutes ago, GoodGoodStudy said: I set up a maincamera based on what you said,But it's still running on a gray screen There might be another world loaded when you attempt to do it at runtime. Try replacing the initial arguments with something like the following: -width 2 -height 1 -extern_plugin Wall -console_command "world_load TestFullScreen.world" Link to comment
GoodGoodStudy Posted January 10 Author Share Posted January 10 I added the parameters you provided, but it didn't work, it looks like the scene didn't load because it didn't print False, I change worldname to TT Link to comment
GoodGoodStudy Posted January 10 Author Share Posted January 10 Also, does this feature only work in editor mode, and the packaged feature won't work? wall plug-in Link to comment
bmyagkov Posted January 10 Share Posted January 10 17 minutes ago, GoodGoodStudy said: I added the parameters you provided, but it didn't work, it looks like the scene didn't load because it didn't print False, It appears there was a bug in the version (2.16.0.1) you're currently using but this issue has been resolved in the subsequent version 2.16.1. Please update your project or create a new one using SDK 2.16.1 and the camera will function as intended. 7 minutes ago, GoodGoodStudy said: Also, does this feature only work in editor mode, and the packaged feature won't work? wall plug-in The Wall plugin is not compatible with the editor and is meant to be used exclusively in a runtime application. You can build the final application with the Wall plugin included and adjust the startup arguments in the same manner as described in the following article: https://developer.unigine.com/en/docs/2.18/editor2/projects/build_project?rlang=cs#launcher Link to comment
GoodGoodStudy Posted January 10 Author Share Posted January 10 Do you have vertical resolution now Link to comment
GoodGoodStudy Posted January 12 Author Share Posted January 12 I package it up, I run the program, but after running it for a while, there's this problem, and then the program flutters. What does that mean? Link to comment
bmyagkov Posted January 12 Share Posted January 12 2 hours ago, GoodGoodStudy said: I package it up, I run the program, but after running it for a while, there's this problem, and then the program flutters. What does that mean? When using the Sim Per-Channel SDK and deploying the release build it is essential to have the IG HASP (Channel USB Dongle) in order to utilize plugins related to multi-monitor setups such as "Wall" and others. For more detailed information, please visit the following link in our documentation: https://developer.unigine.com/en/docs/2.16.1/sdk/licenses/?rlang=cpp#usb_channel Link to comment
