Amerio.Stephane Posted September 20, 2023 Share Posted September 20, 2023 Hi, With 2.17, I create a new project with a template Editor plugin (named MyFeature), and compile it. The plugin LocalMyFeature_editorplugin_double_x64.dll is correctly compiled and placed in bin\plugins\Local\MyFeature. But when the editor is launched, the plugin is not loaded (not visible in the Edtior Plugin Manager window). What am I missing? Link to comment
silent Posted September 21, 2023 Share Posted September 21, 2023 Hi Stephane, Is there any warnings/errors in console? Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
Amerio.Stephane Posted September 21, 2023 Author Share Posted September 21, 2023 The editor_log shows this: 10:12:23 WARNING: Editor.PluginSystem: Your plugin is ignored by UnigineEditor due to incompatible version/precision. 10:12:23 WARNING: UnigineEditor v.2.17.0.1 (double precision) 10:12:23 WARNING: LocalMyFeature_editorplugin_double_x64.dll plugin v.2.17.0.1 (float precision) 10:12:23 WARNING: 10:12:23 WARNING: Plugin precision (float) and Editor precision (double) do not match. 10:12:23 WARNING: Your project seems to be configured improperly. Try adding the UNIGINE_DOUBLE preprocessor definition to your plugin project and rebuilding it. But the plugin IS compiled with UNIGINE_DOUBLE: (In fact, no modification has been made from the files installed by the SDKBrowser created project) Link to comment
silent Posted September 21, 2023 Share Posted September 21, 2023 Yep, that's a bug in SDK Browser template generation. Please check this post that contains a fix: https://developer.unigine.com/forum/topic/8707-solved-compile-the-library-with-double-precision-support/?do=findComment&comment=42581 How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
Amerio.Stephane Posted September 21, 2023 Author Share Posted September 21, 2023 Indeed. So for completeness, the vcxproj contains the MOC step, which uses $(MOC_DOUBLE) which should be evaluated to -DUNIGINE_DOUBLE but for some reason this setting is missing in 2.17. Simply replacing $(MOC_DOUBLE) with -DUNIGINE_DOUBLE is enough to make it work. But for a more robust fix, where would you set the MOC_DOUBLE variable? Link to comment
silent Posted September 21, 2023 Share Posted September 21, 2023 That's internals of SDK Browser and due to the bug in SDK Browser this line is not being replaced to the correct form. Once SDK Browser will recieve an update we hope that this behavior will be also fixed :) How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
