ivan.cuevas Posted September 27, 2011 Share Posted September 27, 2011 Hi all, In our application, Unigine window covers two monitors, the problem in when you show a widget centered, like DialogMessages, it appears in the middle of the screens and it's a little bit annoying. A generic and intuitive solution is to add a new parameter to show() method called parent (default value is NULL). By default it works as always being the dialog window child of engine.gui, but if you optionally pass a valid widget reference, the dialog is centered to that parent widget. This is the implementation for DialogMessage: /* message dialog */ namespace DialogMessage { // ... /* show dialog modal and return result */ int show(string title,string message,int button_flags,Widget parent=NULL) { // init gui init(); window.setText(title); label.setText(message); // generate buttons by given flags foreachkey(int b; button_names) { if(b & button_flags) { WidgetButton button = new WidgetButton(gui,button_names[b]); if(button_images[b] != "") button.setImage(new Image(button_images[b])); button.setCallback(GUI_CLICKED,"DialogMessage::button_clicked",:huh:; hbox.addChild(button); buttons.append(button); } } window.arrange(); // enter hotkey for first button and Esc for last buttons[0].setCallbackAccel(GUI_CLICKED,APP_KEY_RETURN,0,0,0); buttons[buttons.size() - 1].setCallbackAccel(GUI_CLICKED,APP_KEY_ESC,0,0,0); // show window if(parent == NULL) { gui.addChild(window,GUI_ALIGN_OVERLAP | GUI_ALIGN_CENTER); } else { parent.addChild(window, GUI_ALIGN_OVERLAP); window.setPosition((parent.getWidth() - window.getWidth())/2,(parent.getHeight() - window.getHeight())/2); } window.setPermanentFocus(); // wait until user close dialog dialog_result = -1; while(dialog_result < 0) wait 1; // close window if(parent == NULL) gui.removeChild(window); else parent.removeChild(window); shutdown(); return dialog_result; } // ... } Link to comment
