[SOLVED] Sandworm crash when create a new project
MySDK version is Sim perchannel 2.14  on windows 10 64bit professional
When I try to use [Sandsworm] from [tool] menu, and click [Next] button , the whole editor will dispear (crashed)
My Hardware is :
GPU : RTX3080
CPU : i7
Memory : 64GB.
My questions are
1:) why ?
2:) How can I get some log or error info? (since I have installed SDK browser 2 with no problem ).
Edited by leon.dong
Thanks silent.
Tried several times, but not working .
Is there any .net framework SDK issue related ?
Edited by leon.dong
36 minutes ago, leon.dong said:
Thanks silent.
What is your operating system? Can you please confirm if the /bin folder in your project contains the "gdal3data" and "gdal3plugins" folders?
My OS is windows 64bit professional.
Dx is 12 .
Under project/bin folder , looks the content of gdal3data and gdal3plugins fine.
Could you please check if your system has some "GDAL_DATA" or "PROJ_LIB" variables, which can be found by opening the "Environment Variables" as shown in the attached image?
I have these two vars in System vars only ,pleaes see below. (It seems the target foler has content )
This might be the cause of the problem. Please remove these variables and restart your computer before trying to run the Sandworm Tool again.
The issue is happening because the GDAL plugin is using the wrong system environment path and looking in the wrong location instead of using the right data from the /bin folder in your project.
yes , confirmed ,problem solved.
thanks.
thanks.
You’re welcome!
  • silent changed the title to [SOLVED] Sandworm crash when create a new project
