xiaoChen Posted August 11, 2022 Posted August 11, 2022 as you can see sssss is On, material is using sssss type is opaque PBR. change any value or disable not change,is something option need setting?
vvvaseckiy Posted August 11, 2022 Posted August 11, 2022 Hi xiaoChen, Could you please show additinal parameters of material. For applying of SSSS material has to be translucent, so if value of Tanslucent parameter set to 0, subsurface scattering won't be appliet to it.
xiaoChen Posted August 11, 2022 Author Posted August 11, 2022 ok thanks! add Tanslucent value in material it work !
