yann.takvorian Posted February 19, 2022 Share Posted February 19, 2022 Hi there, As a newbee in this IG, how (using C++ project) to just load a world (like Unigine\Unigine SDK Browser\addons\airport_assets_addon_2.15\data\airport_assets.world) and set the camera in the center ? In which file to add it ? Thanks Link to comment
cash-metall Posted February 21, 2022 Share Posted February 21, 2022 Hi! you need to specify path to world in ig_config.xml <databases> <database id="1" world_name="path/to/world.world" geodetic_origin="0 0 0"/> </databases> and after that load database through cigi ig_control packet or through API ig_manager->loadDatabase(1); camera should be in center by default. you can control view througth cigi view_control packet or through API View * view = ig_manager->getView(0); view->setPosition(position); 1 Link to comment
yann.takvorian Posted February 23, 2022 Author Share Posted February 23, 2022 Thanks, but it does not work. Got error with geodetic plugin missing GDAL complaints, etc. Maybe I am too ambitious. Have you succeeded in simply loading a FBX object ? I tried using: node = World::loadNode("H:\Unigine\Unigine SDK Browser\sdks\evaluation_sim_windows_2.15\data\samples\common\fbx\yol.fbx"); and getting: Xml::load(): can't load "H:\Unigine\Unigine SDK Browser\sdks\evaluation_sim_windows_2.15\data\samples\common\fbx\yol.fbx" file World::loadNode(): bad node file "H:/Unigine/Unigine SDK Browser/sdks/evaluation_sim_windows_2.15/data/samples/common/fbx/yol.fbx" Link to comment
cash-metall Posted February 24, 2022 Share Posted February 24, 2022 Unigine has own format .node - it can be of NodeReference or NodeLayer. (something like "prefab") you need import your fbx Link to comment
yann.takvorian Posted February 28, 2022 Author Share Posted February 28, 2022 Ok, I was able to do that after fixing the FBX using Blender (export with textures copied). Thanks Link to comment
