Amerio.Stephane Posted December 15, 2021 Share Posted December 15, 2021 Hi, Could you please detail how to replace this from 2.14 to 2.15: // 2.15: setPostMaterials is not part of PlayerSpectator spectator->setPostMaterials("vr_post_filter_selection"); // 2.15: findMaterial is not part of Materials Materials::findMaterial("abcd") // "abcd" is based on mesh_base Thanks! Link to comment
sweetluna Posted December 15, 2021 Share Posted December 15, 2021 Hi Amerio.Stephane, Post materials were removed, you use Scriptable Materials instead as a more flexible replacement. That involves updating both shaders and materials, we recommend to upgrade old XML Basemat's to ULON format for future, as we plan on removing XML Basemats in 2.16. Instead of setPostMaterials use addScriptableMaterial. Instead of Materials::findMaterial("abcd") use Materials::findMaterialByPath (requires full path to the file with file extension) or findMaterialByGUID. API Migration Guide Regarding fastest changes that can be done to materials/shaders: 1. Ensure that you use full paths to shader files, instead of just file names 2. We removed auto (& renamed) MRT/Render Target declarations in 2.15. Declare them explicitly: STRUCT_FRAG_BEGIN INIT_COLOR(float4) STRUCT_FRAG_END 3. Use new path to base shader includes: core/shaders/common/common.h -> core/materials/shaders/render/common.h and others 4. Make sure that you use correct shader body declarations: MAIN_BEGIN(VERTEX_IN, FRAGMENT_IN) MAIN_END MAIN_FRAG_BEGIN(FRAGMENT_IN) MAIN_FRAG_END MAIN_COMPUTE_BEGIN(x, y, z) MAIN_COMPUTE_END MAIN_EVALUATE_BEGIN(EVALUATE_OUT, EVALUATE_IN) MAIN_EVALUATE_END MAIN_CONTROL_BEGIN(CONTROL_OUT, CONTROL_IN) MAIN_CONTROL_END MAIN_PATCH_CONSTANT_BEGIN(CONTROL_IN) MAIN_PATCH_CONSTANT_END 1 1 May RenderDoc/Nsight Graphics/Intel GPA bless you Link to comment
