Amerio.Stephane Posted December 9, 2021 Share Posted December 9, 2021 (edited) Hello, 2.13.1.1 here and I try to have a callback called when a slave is connected. So I use this code in the init of a SystemLogic module: int MySystemLogic::init() { auto ig = IG::Manager::get(); ig->addOnSlaveConnectedCallback(this, MakeCallback(this, &MySystemLogic::onSlaveConnected)); //< This callback is never called return 1; } But the callback is never called. Instead, if I use the Syncker directly then its callback is correctly called: int MySystemLogic::init() { auto ig = IG::Manager::get(); if (ig->isMaster()) ig->getSynckerMaster()->addCallback(Syncker::Master::SLAVE_CONNECTED, MakeCallback(this, &MySystemLogic::onSynckerSlaveConnected)); // now the callback is correctly called when a slave is connected return 1; } What am I missing? Edit: How can I know when the slave is fully ready? (because apparently the Syncker "slave connected" callback is called *before* the manager send the full state to the slave, so my callback is useless as the moment) Edited December 9, 2021 by Amerio.Stephane Link to comment
cash-metall Posted December 9, 2021 Share Posted December 9, 2021 1 hour ago, Amerio.Stephane said: But the callback is never called. Instead, if I use the Syncker directly then its callback is correctly called: its strange behavior, because IG::onSlaveConnected called directly from Master::SLAVE_CONNECTED callback // IGManager void Manager::init() { //... syncker_master->addCallback(Plugins::Syncker::Master::SLAVE_CONNECTED, MakeCallback(this, &Manager::on_slave_connect)); syncker_master->addCallback(Plugins::Syncker::Master::SLAVE_DISCONNECTED, MakeCallback(this, &Manager::on_slave_disconnect)); syncker_master->addCallback(Plugins::Syncker::Master::SESSION_CONTINUED, MakeCallback(this, &Manager::on_session_continued)); //... } //... void Manager::on_slave_connect(int index) { String view = getSlaveName(index); if (ig_ready) extra_slaves.append(view); RUN_CALLBACKS(SlaveConnected, index, view.get()); // {for (auto &callback : OnSlaveConnecedCallbacks) callback.data->run(__VA_ARGS__);} } full state sent to the slave in Master::SESSION_CONTINUED callback for the new extra_slave (connected after session start) void Manager::on_session_continued() { // create and send full state to each slave (including existing) BlobPtr blob = Blob::create(); saveState(blob); net.send(FULL_STATE, database_id, uint64_t(blob->getSize()), &blob); Log::message("%s(): sent full state to slaves (%d bytes)\n", __IFUNC__, blob->getSize()); // set view to new extraslave for (int i = 0; i < extra_slaves.size(); i++) { String &view = extra_slaves[i]; setSlaveView(view, slave_views.contains(view) ? slave_views[view] : current_view_id); } // clear queue extra_slaves.clear(); } you can also subscribe to this callback - it will be called after the IG callback. I will try to check what is happening with the callbacks, but only next week - we all in preparing release 2.15 Link to comment
Amerio.Stephane Posted December 10, 2021 Author Share Posted December 10, 2021 SESSION_CONTINUED fits my need so that's perfect at the moment! Thanks for the explanation! Link to comment
