Phil_T Posted November 25, 2020 Share Posted November 25, 2020 I'd like to see some more info in the Node Reference guide. Specifically, about the limitations. For example, it doesn't look like I'm able to adjust physics of a particular instance say to connect multiple instances with joints but it appears mesh instances are created when running the app so maybe it's possible to programmatically modify individual instances. You mention that using Node References means you can edit a single version and have changes propagated to all instances but if these are proer instances, performance will also be improved. It might be useful to mention that. Thanks, Phil Link to comment
silent Posted November 27, 2020 Share Posted November 27, 2020 Hi Phil, Thank you for the feedback. Will try to improve this in the future documentation updates :) 1 How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
