Phil_T Posted November 4, 2020 Share Posted November 4, 2020 Hi all, I'm just evaluating this engine for a game I'm creating and wondered if it's possible to build with F#. F# could interface with the C# API but without digging deeper I'm not sure if the engine would allow the 2 languages to be compiled together. I'm just not sure how it currently works with the C# integration and whether I'd be possible to give it any old .NET code. Cheers, Phil Link to comment
Phil_T Posted November 4, 2020 Author Share Posted November 4, 2020 I'm thinking maybe it can be done a bit like how Unity can be integrated, https://www.davideaversa.it/blog/quick-look-at-f-in-unity/. In other words, by creating an F# class library that could be linked to. Link to comment
silent Posted November 5, 2020 Share Posted November 5, 2020 Hi Phil, You can definitely use F# in combination with a C#, but the performance of such solution would be far for the more or less complex realtime application :) You can check some numbers from this stream from Stefano Casillo: You can get more performance in case if we would expose the raw C API (that is still planned, but I can't give you an exact ETA). C API for 2.11 SDK can be found here: https://github.com/nxrighthere/Unigine-C How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
Phil_T Posted November 5, 2020 Author Share Posted November 5, 2020 Thanks. Nice video! I'm just starting out so performance wouldn't be an issue for now. I've done some C API integration before so this could definitely be an option later down the line. Link to comment
