F# Support?
Hi all,
I'm just evaluating this engine for a game I'm creating and wondered if it's possible to build with F#. F# could interface with the C# API but without digging deeper I'm not sure if the engine would allow the 2 languages to be compiled together. I'm just not sure how it currently works with the C# integration and whether I'd be possible to give it any old .NET code.
Cheers,
Phil
Link to post
Hi Phil,
You can definitely use F# in combination with a C#, but the performance of such solution would be far for the more or less complex realtime application :)
You can check some numbers from this stream from Stefano Casillo:
You can get more performance in case if we would expose the raw C API (that is still planned, but I can't give you an exact ETA). C API for 2.11 SDK can be found here: https://github.com/nxrighthere/Unigine-C
Link to post
Thanks. Nice video! I'm just starting out so performance wouldn't be an issue for now. I've done some C API integration before so this could definitely be an option later down the line.
Link to post
