davide445 Posted June 17, 2020 Share Posted June 17, 2020 (edited) Trying to import a DEM based heightmap elaborated in Houdini. The attached file result from this to this result but still in Unigine 2.10 the resulting LandscapeTerrain Converted in R16 using Houdini output, packed raster, single channel, 16b fixed, height output layer in R. The height range is correct 1296m. smooth_steep_areas2.hiplc converted_heightmap.tga Edited June 17, 2020 by davide445 Link to comment
thomalex Posted June 18, 2020 Share Posted June 18, 2020 Hello @davide445, your Houdini project works fine for me. The only issue was with the TGA 16 bit fixed output, somehow it was saved in 8 bits anyway (maybe it's the problem of Houdini output or even the format itself) while PNG and TIFF were totally ok. Try using these formats. Thanks! 1 Link to comment
davide445 Posted June 18, 2020 Author Share Posted June 18, 2020 @thomalex what Image Output settings did you use to output the heightmap for Unigine? Link to comment
thomalex Posted June 18, 2020 Share Posted June 18, 2020 @davide445 the following usual ones: Also, make sure to have the appropriate Image Format when importing the image. Link to comment
davide445 Posted June 18, 2020 Author Share Posted June 18, 2020 (edited) @thomalexI work on terrains rarely and based my settings on this conversation with morbid He suggested to use Single Channel as Format, will this make any difference? Also wondering now if 32F mean fixed or float. Apologize not doing my research before, find more efficient to ask experts instead of testing all the combinations. Edited June 18, 2020 by davide445 Link to comment
thomalex Posted June 19, 2020 Share Posted June 19, 2020 @davide445 These suggestions related to the Landscape Tool used for Terrain Global generation. Since you're using the Lanscape Terrain, you can use textures with any number of channels and specify the channel that contains your heightmap data in the Landscape Layer Map import settings. 32F is for Float, for sure. Thanks! 2 Link to comment
