Light through walls
Hello! I have a problem! When i add light no matter which one, it passes through object like wall on my image, i have one more light on cieling and it blocked by a cube, but it passes light through it, shodows turned on, no gaps anywhere!! Why it happens?!
Can you be more specific? Is it an Omni/Proj Light behind the wall? Or is it Voxel Probe artifacts?
Can you repro this artifact with garage box and light source only?
Thanks.
Hello! Thanks for answer!! Light source is no matter! They all gives the same result!
Light is outside walls
As you can see when garage contact floor at some places it gives light spots inside garage! And yes, there's no gaps it even go under the floor a bit!
I give you my geometry, you can reproduce effect, to see what happens!
test-02.fbx
Edited by vasia.vlasov
