[SOLVED] NuGet Package Usage Breaks Unigine Build
I added a NuGet Package to my project, and whenever I build I received this error.
Whenever I comment out the code actually using the package the project will build fine like before. Below is the code that breaks the build process.
using System;
using System.Collections;
using Unigine;
using LiteNetLib;
[Component(PropertyGuid = "80c9ad2c0af8469b9c4f4b3e1d7e7985fe431d20")]
public class Server : Component
   NetManager LiteServer;
    private void Init() {
        Log.Message("Server component init finished!\n\n");
    ~Server() {
	private void Update()
        if(Engine.VideoApp == "null") {
Commenting out the NetManager line allows builds to continue.
Another solution I tried as copying the .dll for the library into my project and adding it as an assembly reference. I still receive the same type of error as above.
  • silent changed the title to [SOLVED] NuGet Package Usage Breaks Unigine Build
