ahmad.karami Posted April 25, 2020 Share Posted April 25, 2020 (edited) Hi Unigine Team, My Hardware & My Software OS : Windows 10 - 64 bit Game Engine : Unigine 2.11.0.1 Free Version CPU : Corei7 - 4GHZ GC : NVidia GTX 760 - 2GB Real RAM : 16 GB HDD : 1 TB Reproduction Bug: I can not cause sometimes it happens. I recorded a video for you , plus , I did not add tags to my video && this is unlisted video ;-) Also, I said you , this Right/Left mouse bugs exist in this post & I mentioned that last post. Thank You Edited April 25, 2020 by ahmad.karami Link to comment
bmyagkov Posted April 28, 2020 Share Posted April 28, 2020 Hello! We are trying to reproduce your problem on empty world but still no result. Would be great If you could capture whole workflow while creating those example step by step using some kind of screen capture tool like OBS or something similar and then share captured video with us? As a temporary solution try to completely remove following file located here - C:\Users\Computer\AppData\Local\Unigine\Editor\editor1.1.cfg and then please check if the problem is reproduced again And by the way, what is yours current display resolution? Is it 1366x768 or less? Thanks! Link to comment
ahmad.karami Posted April 28, 2020 Author Share Posted April 28, 2020 (edited) 1 hour ago, bmyagkov said: Hello! We are trying to reproduce your problem on empty world but still no result. Would be great If you could capture whole workflow while creating those example step by step using some kind of screen capture tool like OBS or something similar and then share captured video with us? As a temporary solution try to completely remove following file located here - C:\Users\Computer\AppData\Local\Unigine\Editor\editor1.1.cfg and then please check if the problem is reproduced again And by the way, what is yours current display resolution? Is it 1366x768 or less? Thanks! Hello @bmyagkov Yes I use this resolution (1366x768) Unfortunately, I can't reproduce it, it happens sometimes, it happened moments ago! also I have only used Camtasia Studio 8.5 for a few years :-) Edited April 28, 2020 by ahmad.karami Link to comment
