daniel.morato Posted April 18, 2020 Share Posted April 18, 2020 Hello there! I'm eager to test out unigine now, as I dive deeper and deeper on the tutorials and examples. One thing I'm missing out is how to export out high quality images, animations and 360 images out of the engine (I'm an achitect and those are really important of archviz scenes!) Can I use Ansel on Unigine? Didn' find a way to make it work. The archviz example is available for community sdk? It's not showing up on my! Thanks in advance! Link to comment
morbid Posted April 18, 2020 Share Posted April 18, 2020 Hi, Yes you can render a 360 images right in the UnigineEditor. Just switch to panorama mode in the settings, then use video grabber tool. Important notice: panorama uses multiple viewports and significantly increases GPU load. You also should disable or configure manually some post effects since they can't be used in panorama mode: exposure should be set to static white balance disabled lens flares disabled You might find these articles useful: Camera effects in UNIGINE (see for exposure and WB) Lens flares Tracker tool (for sequences grabbing) Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
