laurent.ongaro Posted April 11, 2020 Share Posted April 11, 2020 (edited) Hi, I've just installed the 2.11 Community SDK and the C# Api button is disabled in the SDK Browser I'm on Arch Linux Mono is installed and configured (used in other projects that need it, like Godot Engine) I've also noticed the following point in the linux documentation https://developer.unigine.com/en/docs/2.10/code/environment/linux?rlang=cpp Quote You may also need to set the following environment variables: Add to $LD_LIBRARY_PATH variable locations of the following directories: <UnigineSDK>/lib. Re-login to make the changes in ~/.profile take effect. but there is not "lib" sub-folder in the SDK folders Thanks for your answers Edited April 11, 2020 by laurent.ongaro add infos Link to comment
silent Posted April 12, 2020 Share Posted April 12, 2020 Hi Laurent, C# samples are only valid under the .NET Framework 4.x on Windows, they will not work under Mono on Linux. That fact that you seeing it in SDK Browser is more likely a bug, since this category doesn't make any sense right now on Linux and should not be displayed. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
laurent.ongaro Posted April 12, 2020 Author Share Posted April 12, 2020 (edited) OK Silent, Thanks for the reply ! Does this mean that the C # implementation on linux is a kind of subset of Windows and is less "complete" ? I am mainly interested in the C # implementation in Unigine under linux, but should I rely on the documentation and examples that I can find (mainly provided by the Unigine team) to learn it or will they give me contents that may be false, incomplete and/or unusable without external help ? It is important for me to know this, as there is not so much help I can find to learn Unigine, the few available sources must be valid. Otherwise, I could be wasting my time trying to solve or understand a "programming" problem which, in fact, will not be feasible or usable in C# on Linux. In another way, can I consider C# under linux as a mature implementation and start to learn it with existing learning content or will I start a very difficult obstacle course ? Regards Laurent Edited April 12, 2020 by laurent.ongaro Link to comment
silent Posted April 12, 2020 Share Posted April 12, 2020 Hi Laurent, C# Under Linux via .NET Core is fully functional (identical to Windows). You can check Demos -> C# Component Samples / C# Third person platformer to get the idea how to start using it. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
laurent.ongaro Posted April 12, 2020 Author Share Posted April 12, 2020 Ok, good news ! So, I'll go on learning the "Unigine way" to make games Thanks for your quick answer Link to comment
