Albedo doesn't apply to Landscape
Albedo doesn't apply to Landscape.
Landscape at Worl d shows the lods  well. (Same as Landscape Tool)
However,  lod1-5 aren't created in Imagery's Output File.
When generated more small play area, Albedo was properly applied.
Edited by minyoung.lee
13 hours ago, morbid said:
Do you see any errors in the log after generating this terrain?
I haven't seen any errors.
But when I reduce the files in Albedo(5 files) at same Play area, Albedo was applied.
I did some  test. And 8 files(9.37GB) lods are created properly regardless of the size of the Play area. Over 9 files, It doesn't work.
I need generate Albedo 32 files(27.6GB) total.
I also did some tests with tiled albedo and everything worked as expected. I suggest checking the following:
  • Do you have enough space for cache data?
  • Check how LOD calculator works depending on the play area position/size when you add all required tiles, this can be done in the albedo tab. It should recalculate LODs automatically. If not — try adding manual LODs for albedo.
  • If nothing helps please send us textures that are causing this issue, we'll try to find time for this case in the next weeks.
Thanks.
