Walters.Robert Posted September 12, 2019 Share Posted September 12, 2019 I followed the video tutorials on meshclutter's and impostors & believe I have set the switch over distance between the two as recommended in the video. Unfortunately, I occasionally get behavior where the impostor vanishes before the clutter loads which means the object disappears for a second before popping back into existence. Here is a video of the phenomenon. The behavior is inconsistent. After having it happen for a few minutes it will go away. Does it have something to do with how the two objects are loaded into memory? Link to comment
morbid Posted September 13, 2019 Share Posted September 13, 2019 Hello Robert, This could happen due to the lag of clutter cell generation. Can you share the following info: Terrain size Grass and Clutter size, step and density More likely you'll have to adjust step value to make trees appear seamless. Thanks. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
