[SOLVED] Problem with normal map.
After loading the normal map, it works incorrectly. I tried to change the normal maps for the offered options, the result is bad.
What else can you do to make a normal map work?
Stanislav,
Could you please attach your normal map and original geometry in FBX (or which format was used to import) in zip archive to your reply?
That would help us to find out what is causing this.
Is it possible to make it so that only you and your company employees can download? Or is it not provided?
I seem to have nakosyachil himself when exporting from substance, I solved the problem) thanks for the support.
  • Like 3
Great :)
We do recommend to use our texture presets that converts automatically RGB8 normal maps to RG8 (ATI2). It will save GPU memory and increase performance on streaming. Just select Texture preset: Normal Map (RG):
  • silent changed the title to [SOLVED] Problem with normal map.
