ExBemined Posted June 17, 2019 Share Posted June 17, 2019 In the documentation a function named microprofile_dump_csv is mentioned: https://developer.unigine.com/en/docs/2.8/code/console/#microprofile_dump_csv When I try to run this command however (in Unigine 2.8) I get a 'unknown command' error. Also the autocomplete for the console only lists the microprofile_dump_html and microprofile_dump_frames functions. I did a search in the source code of 2.8.0.1 and I cannot find any mention of this function there either. If this a mistake in the documentation, or do I need to load some sort of plugin for this? Link to comment
fox Posted June 17, 2019 Share Posted June 17, 2019 Hi Bemined, Currently dumps are saved to html-files ( microprofile_dump_html command). Seems like a bug in documentation, we'll fix it and update documentation, sorry for the inconvenience caused! Thanks for reporting this issue! Your feedback is always appreciated! Link to comment
ExBemined Posted June 18, 2019 Author Share Posted June 18, 2019 The command was present in the 2.7.3 version (or at least I see a EngineMicroprofile::dumpFileCSV function in the source code, don't have a running version of 2.7.3 here to test it), any reason it was removed from 2.8? Link to comment
silent Posted June 18, 2019 Share Posted June 18, 2019 Bemined CSV export never works as expected. On our test cases it simply causing engine crashes. Also it exports only part of the current html counters, so in general it's not really useful for debugging, so we decided to remove it. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
