piotr.karkocha Posted May 28, 2019 Share Posted May 28, 2019 Hello, I have a problem with objects with switch.prop when performing material switching on them (in VR). I have modified the code of the material laser switcher from this post by fox: so that i can perform material switching on a given node when clicking a button in gui ( it turns out to be more intuitive for the users) and also so that it is performed to all the children in this node´s hierarchy. Firstly i create a vector of materials, and then there is the callback function of my button: void GuiSample::mat_switch2() { insel3 = Editor::get()->getNodeByName("Kitchen_schrank_3"); int children = insel3->getNumChildren(); for (int i = 0; i < children; i++) { ObjectPtr object5 = Object::cast(insel3->getChild(i)); object5->setMaterial(my_materials3[mat_index3], "*"); } if ((mat_index3 + 1) < my_materials3.size()) mat_index3++; else mat_index3 = 0; } Materials switching works fine as long as I don´t use one of the switch objects ( it only has "change rotation" enabled) which also are in the given node´s hierarchy. After that if i click the material switching button once again the application crashes, so I assume there is some conflict with this property. Would be great if you could have a look at it! Link to comment
morbid Posted May 30, 2019 Share Posted May 30, 2019 Hello Piotr, All our devs who can help you with the code are busy at the moment. We'll be able to take a look at your sample next week. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
piotr.karkocha Posted May 30, 2019 Author Share Posted May 30, 2019 Hi Morbid, Thank you for your response! Great:) Link to comment
fox Posted June 4, 2019 Share Posted June 4, 2019 Hi Piotr, You could try something like this (I've changed your code a bit and added a recursive function switchMaterials() for hierarchy processing): // method performing material switching for all child nodes of the corresponding types in the specified node's hierarchy recursively int GuiSample::switchMaterials(NodePtr n) { int res = 0; // no changes (initial value) if (!n) return 0; // nothing to change here // getting node's type to process it (along with the hierarchy) properly int type = n->getType(); // we shall change material only for mesh static, dynamic and clutter/cluster objects to avoid setting mesh_base material to inappropriate object types (e.g. ObjectText, etc.) if ((type == Node::OBJECT_MESH_STATIC) || (type == Node::OBJECT_MESH_DYNAMIC) || (type == Node::OBJECT_MESH_CLUTTER) || (type == Node::OBJECT_MESH_CLUSTER)){ ObjectPtr object5 = Object::cast(n); object5->setMaterial(my_materials3[mat_index3], "*"); // setting the flag, as we've changed the material res = 1; } else // checking whether we've got a node reference to process its hierarchy properly if (type == Node::NODE_REFERENCE){ res = switchMaterials(NodeReference::cast(n)->getReference()); } // trying to change material for all node's children int children = n->getNumChildren(); for (int i = 0; i < children; i++) { res += switchMaterials(n->getChild(i)); } // returning the result: whether we've changed material of the node (or any node in its hierarchy) or not return res; } // your mat_switch2 method (onClick handler for your button) void GuiSample::mat_switch2() { // let it be a button (a switch object used in the default VR Template world) <- you can replace it with your Kitchen_schrank_3 or anything else insel3 = Editor::get()->getNodeByName("button"); // if a material was switched, proceed to the next one in the list if (switchMaterials(insel3)) { if ((mat_index3 + 1) < my_materials3.size()) mat_index3++; else mat_index3 = 0; } } This should work fine for all objects! Hope this helps! Thanks! Link to comment
piotr.karkocha Posted June 12, 2019 Author Share Posted June 12, 2019 Hi Fox! This is very cool:) Thanks a lot! Link to comment
