ken.mayfield Posted June 9, 2011 Share Posted June 9, 2011 Currently it is possible to save out a node as a NodeReference, add it to levels, and have them update everywhere when saved which is awesome. In some cases, though, we wish to add a NodeReference Node, but then make it unique. Is there a way to convert these from NodeReference back to normal unique Node objects in the world? 1 Link to comment
ulf.schroeter Posted June 9, 2011 Share Posted June 9, 2011 Is there a way to convert these from NodeReference back to normal unique Node objects in the world? Might be possible via UNIGINE scripting. Write an appropriate script function e.g. convertNodeReference and add it to console, so you artist can invoke this conversion interactivly via console. Something like the following snippet (NOT tested, so expect errors, but should show principle). I am not sure if there are any issues with referenced node material/property libraries within external node file, as these most probably also will have to be added to loaded world for proper material/property assignment on world reload. You have to test it. #include <core/unigine.h> #include <core/scripts/system.h> int init() { engine.console.addCommand("convertNodeReference ", "convertNodeReference <node_reference_name> convert node_reference to node instance", "convertNodeReference"); return 1; } int shutdown() { return 1; } int update() { return 1; } void convertNodeReference ( string node_reference_name ) { Node node = engine.editor.getNodeByName( node_reference_name ); if( node != 0 ) { NodeReference node_reference = node_cast(node); if( node_reference != 0 ) { Node node_referenced = node_reference.getNode(); Node node_clone = node_referenced.clone(); node_clone.setName( node_reference_name + "_instance" ); node_clone.setParent( node_reference.getParent() ); node_clone.setWorldTransform( node_reference.getWorldTransform() * node_referenced.getTransform() ); engine.editor.addNode( node_clone ); engine.editor.removeNode( node_reference ); } } } Link to comment
ken.mayfield Posted June 9, 2011 Author Share Posted June 9, 2011 I should add this to the feature request area... as it seems like a must have with this system. Link to comment
frustum Posted June 10, 2011 Share Posted June 10, 2011 There is an "import node" button near the "load node reference" button. You can import node reference into the world tree and modify it. Link to comment
