muslaev.ilya Posted April 1, 2019 Share Posted April 1, 2019 Hi, I have application that works on three monitors. Monitors are located as follows: the first and second in line, the third - under the first. I tried to create 1x3 wall or 2x2 wall with one unused monitor - all windows apears on first monitor. If i replace windows manually on correct screens, i can't interact with elements, because mouse coordinates are wrong. Link to comment
alexander Posted April 2, 2019 Share Posted April 2, 2019 Hi Ilya, AppWall doesn't support non-square configurations. But you can try to change the source code of AppWall plugin for your case. The source code is here: <Unigine SDK Browser>\sdks\<sdk_version>\source\plugins\App\AppWallI can't interact with elements, because mouse coordinates are wrong Can you give me more information? What does it mean? GUI with the mouse are rendered on "primary" window only. App::getMouseX() and App::getMouseY() give you coordinates of the mouse relative to primary window. Best regards, Alexander Link to comment
muslaev.ilya Posted April 2, 2019 Author Share Posted April 2, 2019 I use MOUSE_SOFT in my project, so i can see mouse in all screens. For two monitors everything works correct. 1 - I create app with three screens -width 3 -height 1 -extern_plugin "AppWall", but in windows i use my configeration (see attached image) 2 - App create all screens in one monitor. I manually replace them on correct monitors. 3 - When i press on buttons - nothing happens, but if first (screen with buttons on it) and second (empty screen) are in one monitor, click causes callback. Link to comment
silent Posted April 3, 2019 Share Posted April 3, 2019 Hi Ilya, Engine knows nothing about actual physical location of displays. -width 3 -height 1 assume that all monitors are located in a single row. In that case I belive you need to write your own mouse handling code that will fit your needs. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
