dongju.jeong Posted January 22, 2019 Share Posted January 22, 2019 (edited) The imposter LOD visibility range setting is rather strange. It appears that a value greater than the setting has been applied. If you set the mesh's LOD Max Visibility value to 60 and the Imposter LOD's Min Visibility value to 60, I can not create a smooth connection. Importer nodes are rendered late. I tested with pine_01_1.node of vegetation add ons. and... other question, Where can I change the visible distance of the shadow being rendered? Edited January 22, 2019 by dongju.jeong Link to comment
morbid Posted January 22, 2019 Share Posted January 22, 2019 Hello @dongju.jeong, 6 hours ago, dongju.jeong said: It appears that a value greater than the setting has been applied Have you checked Fade distance value? It actually applies to the Visibility distance. 6 hours ago, dongju.jeong said: Where can I change the visible distance of the shadow being rendered? You can find global shadow distance settings in Windows -> Settings -> Render - Visibility distances: https://developer.unigine.com/en/docs/2.7.3/editor2/settings/render_settings/visibility_distances/ Thank you! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
dongju.jeong Posted January 24, 2019 Author Share Posted January 24, 2019 I set both fade value 10. or 0 Maybe I made the wrong imposter. I test it in this project. there is one tree in world. test_geoTerrain.7z Link to comment
dongju.jeong Posted January 24, 2019 Author Share Posted January 24, 2019 (edited) I think it's because of the space gap. Is there a way to reduce the amount of space an Imposter occupies? a few test later, set higher the value of the fade, the more natural it became.(60+) If no special problem occurs, I'll set higher value of fade and just use it. Edited January 24, 2019 by dongju.jeong Link to comment
morbid Posted January 24, 2019 Share Posted January 24, 2019 8 hours ago, dongju.jeong said: I think it's because of the space gap Yes, you're right. This gap is created intentionally for proper billboard rotation. Usually, trees are created as Clutter objects. You can use Impostors Creator with clutter which is much easier than baking single tree to a billboard. Please, check this article: https://developer.unigine.com/en/docs/2.7.3/editor2/tools/impostors_creator/ Thank you. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
