Walters.Robert Posted November 5, 2018 Share Posted November 5, 2018 https://developer.unigine.com/en/docs/2.7.2/code/cpp/usage/variables I'm trying to follow the above example on making a variable usable in UnigineScript from C++. When I attempt the above I get the error that the function MakeExternVariable is not defined. I also couldn't find it anywhere else in the documentation. When I try to put anything else into the second argument of addExternVariable I get the error "argument of type float is incompatible with Unigine::ExternVariableBase* . my code: void AppWorldLogic::entity_control(Cigi::ICigiEntityControl* control) { // getting values from the incoming Host packet Math::dvec3 receivedPosition; int entityType = control->getEntityType(); if (entityType == 0) { receivedPosition = control->getPosition(); Math::dvec3 cartesianPosition; //Math::vec3 eulerAngles; vec3 eulerAngles = control->getRotation(); float roll = eulerAngles.x; Interpreter::addExternVariable("myRoll",roll); Log::warning("\nEuler angles for aircraft %d (roll, pitch, yaw) = (%f, %f, %f) \n", entityType, eulerAngles.x, eulerAngles.y, eulerAngles.z); } // if type 0 }// entity_control Link to comment
fox Posted November 6, 2018 Share Posted November 6, 2018 Hi Robert, the MakeExternVariable() function is defined in the UnigineInterface.h file, so you have to include it too: #include <UnigineInterface.h> This should solve the problem. Seems like there was a bug, we shall restore missing description in the documentation by the upcoming release. Sorry for the inconvenience caused! Thank you! Link to comment
Walters.Robert Posted November 6, 2018 Author Share Posted November 6, 2018 Thanks! I can now compile the C++ code without error, however, I'm still having issues getting the script side to recognize the exported variables. from the C++ side #include "AppWorldLogic.h" #include <UnigineEditor.h> #include <UnigineGame.h> #include <UnigineApp.h> #include <UnigineInterpreter.h> #include <UnigineInterface.h> using namespace Unigine; using namespace Cigi; using namespace Math; void AppWorldLogic::entity_control(Cigi::ICigiEntityControl* control) { // getting values from the incoming Host packet Math::dvec3 receivedPosition; int entityType = control->getEntityType(); if (entityType == 0) { receivedPosition = control->getPosition(); Math::dvec3 cartesianPosition; //Math::vec3 eulerAngles = vec3(1.0f,2.0f,3.0f); vec3 eulerAngles = control->getRotation(); //float roll = eulerAngles.x; // export a variable and specify a name to access it from Unigine scripts Interpreter::addExternVariable("eulerAngles", MakeExternVariable(&eulerAngles)); Log::warning("\nEuler angles for aircraft from cpp %d (roll, pitch, yaw) = (%f, %f, %f) \n", entityType, eulerAngles.x, eulerAngles.y, eulerAngles.z); } // if type 0 }// entity_control from the unigine script side: #include <core/unigine.h> #include <core/systems/tracker/tracker.h> #include <helicopter.h> #include <ship.h> #include <quality_settings/quality_settings.h> using Unigine::Tracker; int update() { /*....lots of other code here...*/ log.message("Euler angles accessed from the script are " + eulerAngles + " \n"); return 1; } Here is the resulting error message. log.message("Euler angles accessed from the script are " + eulerAngles + " \n"); demos/oil_platform/oil_platform.cpp:955: Interpreter::parse_expression(): unknown token "eulerAngles" in ""Euler angles accessed from the script are " + eulerAngles + " \n"" expression Is this a scope issue? I thought that the exported variable would be global and accessible from any part of the script. Link to comment
christian.wolf2 Posted November 6, 2018 Share Posted November 6, 2018 Hi Robert, exporting UNIGINE classes and variables are pretty easy, but in order to use it in script side you need to create a plugin (at least the way I use it). https://developer.unigine.com/en/docs/2.7.2/code/cpp/plugin Link to comment
Greg.Mildenhall Posted November 7, 2018 Share Posted November 7, 2018 The first thing I notice is that your eulerAngles variable is going out of scope at the end of entity_control() - in the doco you linked to the variables never go out of scope because they're declared in main(). Link to comment
