eugene.litvinov Posted May 17, 2011 Share Posted May 17, 2011 We use xml to describe locale string table, for example, one node can be: <calendar_desc> <font size="24"> Алый мрак в небесной черни </font> <br/> — Алый мрак в небесной черни<br/> Начертил пожаром грань.<br/> Я пришел к твоей вечерне,<br/> Полевая глухомань. </calendar_desc> this node describe Russian text, that will be set to WidgetLabel::setText() that can view rich formatted text. So this node can contain only text, or some rich text tags and/or simple text. How could I parse this node, that set it to WidgetLabel and see correct rich text? I used Xml::getData(), but this works only with simple text, and ignores all included rich tags. Thanks. 1 Link to comment
ulf.schroeter Posted May 17, 2011 Share Posted May 17, 2011 Use a CDATA section which starts with "<![CDATA[" and ends with "]]>" for your node data. Some more details here Link to comment
michael.zhang Posted May 17, 2011 Share Posted May 17, 2011 Try: Xml::getSubTree Xml::getFormattedSubTree Which returns to you the Xml code itself. Link to comment
eugene.litvinov Posted May 18, 2011 Author Share Posted May 18, 2011 It looks like Unigine have some own XML-specification, cause it can load and view in WidgetLabel this xml correct: <calendar_desc value=" <font size=24> Алый мрак в небесной черни </font> <br/> <br/> — Алый мрак в небесной черни<br/> Начертил пожаром грань.<br/> Я пришел к твоей вечерне,<br/> Полевая глухомань. "/> But in valid xml this attribute throw an error, cause in xml attributes we can not use < > & " ' symbols. In valid xml this symbols must be replaced theirs equals: & < > " "'. If we do it Unigine correct load this xml, but in this case in WidgetLabel we see this text: <font size=24>Алый мрак в небесной черни</font><br/><br/>— Алый мрак в небесной черни<br/>Начертил пожаром грань.<br/>Я пришел к твоей вечерне,<br/>Полевая глухомань. It seems like WidgetLabel replace & < > " "' to < > & " ' but "not see" their real destination. Maybe this is a bug, and WidgetLabel must correct convert and use this tags (not only convert, like now)? 1 Link to comment
frustum Posted May 22, 2011 Share Posted May 22, 2011 Widget rich text parser is fixed. Link to comment
