lightmap Posted October 19, 2018 Share Posted October 19, 2018 Hello All works fine with Vive HMD+2Base+2Controllers, but after adding Vive Tracker in Vive device update it recognized as controller (and controller stops tracking) at start VIVE HMD:0 VIVE TRACKING:1 VIVE TRACKING:2 VIVE TRACKER:3 <---- ok VIVE CONTROLLER:4 VIVE CONTROLLER:5 VIVE TRACKER:6 at runtime update VIVE HMD:0 VIVE TRACKING:1 VIVE TRACKING:2 VIVE CONTROLLER:3 <---- here VIVE CONTROLLER:4 VIVE CONTROLLER:5 VIVE TRACKER:6 public static void UpdateDevicesId() { int curTracking = 0, curController = 0, trackers = 0; for (int i = 0; i < MAX_TRACKED_DEVICE_COUNT; i++) { TRACKERS[i] = -1; switch (GetDeviceType(i)) { case TRACKED_DEVICE_INVALID://0 //System.Console.WriteLine($"VIVE INVALID:{i}"); any other empty slot break; case TRACKED_DEVICE_TRACKING://4 System.Console.WriteLine($"VIVE TRACKING:{i}"); if (curTracking == 0) BASE_1 = i; else BASE_2 = i; curTracking++; break; case TRACKED_DEVICE_CONTROLLER://2 System.Console.WriteLine($"VIVE CONTROLLER:{i}"); if (curController == 0) CONTROLLER_1 = i; else CONTROLLER_2 = i; curController++; break; case TRACKED_DEVICE_HMD://1 System.Console.WriteLine($"VIVE HMD:{i}"); HMD = i; break; case TRACKED_DEVICE_OTHER://1000 System.Console.WriteLine($"VIVE OTHER:{i}"); break; case TRACKED_DEVICE_TRACKER://3 System.Console.WriteLine($"VIVE TRACKER:{i}"); TRACKERS[trackers++] = i; break; default: System.Console.WriteLine($"VIVE UNKNOWN:{i} type={GetDeviceType(i)}"); break; } } } is there any way to fix that, or work around? Link to comment
lightmap Posted October 20, 2018 Author Share Posted October 20, 2018 (edited) once after system reboot it seems correct, but after some time it start to redetect tracker as 3th controller and real controller buttons stops working without trackers all working good Edited October 20, 2018 by lightmap Link to comment
silent Posted October 21, 2018 Share Posted October 21, 2018 That's would be tough to reproduce sine we don't have a vive tracker currently in-house. Could you please give us some additianal information like: SDK Version HTC Vive tracker version (1.0 / 2.0) Have you tried to recompile existing plugin with the latest OpenVR manually? Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
lightmap Posted October 22, 2018 Author Share Posted October 22, 2018 Hello Unigine 2.6.1 ViveTracker2.0 downloaded openvr-1.0.17.zip, recompiled AppVive plugin, replaced dll's for project, updated firmware for trackers at start VIVE HMD:0 VIVE TRACKING:1 VIVE CONTROLLER:2 VIVE TRACKING:3 VIVE CONTROLLER:4 VIVE TRACKER:5 VIVE TRACKER:6 <----- ok at runtime VIVE HMD:0 VIVE TRACKING:1 VIVE CONTROLLER:2 VIVE TRACKING:3 VIVE CONTROLLER:4 VIVE TRACKER:5 VIVE CONTROLLER:6 <--- not ok - 3th controller ? all bad, help Link to comment
silent Posted October 23, 2018 Share Posted October 23, 2018 If you have an access to the Unigine 2.7.2.1 could you please try to copy AppVive sources from here and do a plugin rebuild one more time (to link against your 2.6.x SDK)? If that doesn't help we will think what else we can do with that. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
lightmap Posted October 24, 2018 Author Share Posted October 24, 2018 EnginePlugins::addPlugin(): can't load "AppVive_x64d.dll" library 127 Link to comment
silent Posted October 24, 2018 Share Posted October 24, 2018 127 error is basically general windows error while loading any library (some dependencies are missing or has the wrong version [x86/64 conflicts as well]). You can use Dependencies software (https://github.com/lucasg/Dependencies/releases) to find out which library is missing. More likely it has some connection with openvr_api.dll. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
lightmap Posted October 24, 2018 Author Share Posted October 24, 2018 replaced openvr_api.dll to openvr-1.0.17 version now it says ?replace@String@Unigine@@QEBA?AV12@PEB0H@Z not found, AppVive_x64d.dll Link to comment
silent Posted October 24, 2018 Share Posted October 24, 2018 It seems that you have linked AppVive to the wrong engine version. Please, make sure that you link against the Unigine 2.6.x. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
lightmap Posted October 24, 2018 Author Share Posted October 24, 2018 ---- Engine ---- UNIGINE Engine Version: 2.6.1 ver-2.6-cef3c5e Dec 21 2017 Link to comment
silent Posted October 24, 2018 Share Posted October 24, 2018 Yep, I can see that you are launching the engine with correct version, however, during the AppVive building process you need to link it with a correct engine version and specify correct include path from 2.6.1 SDK. But, let's forget about this for a moment, since I've also found that some of the OpenVR users are experiencing almost the same issue that you have after recent SteamVR updates: https://github.com/ValveSoftware/openvr/issues/902 https://steamcommunity.com/app/250820/discussions/0/1728711392740032582/ Here is the release notes of SteamVR update: https://steamcommunity.com/games/250820/announcements/detail/1697186829260359619 So the solution can be actually to change the trackers settings inside SteamVR app as described in release notes. Please, let us know if these somehow helps. Thanks! 1 How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
lightmap Posted October 24, 2018 Author Share Posted October 24, 2018 Thank you, I'll try to use serial, or rollback steam Link to comment
silent Posted October 24, 2018 Share Posted October 24, 2018 Or maybe update to the latest SteamVR beta as well will help - who knows :) How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
