Vive Tracker muddle up with controller
Hello
All works fine with Vive HMD+2Base+2Controllers, but after adding Vive Tracker in Vive device update it recognized as controller (and controller stops tracking)
at start
VIVE HMD:0
VIVE TRACKING:1
VIVE TRACKING:2
VIVE TRACKER:3 <---- ok
VIVE CONTROLLER:4
VIVE CONTROLLER:5
VIVE TRACKER:6
at runtime update
VIVE HMD:0
VIVE TRACKING:1
VIVE TRACKING:2
VIVE CONTROLLER:3 <---- here
VIVE CONTROLLER:4
VIVE CONTROLLER:5
VIVE TRACKER:6
        public static void UpdateDevicesId()
            int curTracking = 0, curController = 0, trackers = 0;
            for (int i = 0; i < MAX_TRACKED_DEVICE_COUNT; i++)
                TRACKERS[i] = -1;
                switch (GetDeviceType(i))
                    case TRACKED_DEVICE_INVALID://0
                        //System.Console.WriteLine($"VIVE INVALID:{i}"); any other empty slot
                        break;
                    case TRACKED_DEVICE_TRACKING://4
                        System.Console.WriteLine($"VIVE TRACKING:{i}");
                        if (curTracking == 0) BASE_1 = i; else BASE_2 = i;
                        curTracking++;
                        break;
                    case TRACKED_DEVICE_CONTROLLER://2
                        System.Console.WriteLine($"VIVE CONTROLLER:{i}");
                        if (curController == 0) CONTROLLER_1 = i; else CONTROLLER_2 = i;
                        curController++;
                        break;
                    case TRACKED_DEVICE_HMD://1
                        System.Console.WriteLine($"VIVE HMD:{i}");
                        HMD = i;
                        break;
                    case TRACKED_DEVICE_OTHER://1000
                        System.Console.WriteLine($"VIVE OTHER:{i}");
                        break;
                    case TRACKED_DEVICE_TRACKER://3
                        System.Console.WriteLine($"VIVE TRACKER:{i}");
                        TRACKERS[trackers++] = i;
                        break;
                    default:
                        System.Console.WriteLine($"VIVE UNKNOWN:{i} type={GetDeviceType(i)}");
                        break;
is there any way to fix that, or work around?
once after system reboot it seems correct,
but after some time it start to redetect tracker as 3th controller
and real controller buttons stops working
without trackers all working good
Edited by lightmap
That's would be tough to reproduce sine we don't have a vive tracker currently in-house.
Could you please give us some additianal information like:
  1. SDK Version
  2. HTC Vive tracker version (1.0 / 2.0)
  3. Have you tried to recompile existing plugin with the latest OpenVR manually?
Hello
Unigine 2.6.1
ViveTracker2.0
downloaded openvr-1.0.17.zip, recompiled AppVive plugin, replaced dll's for project, updated firmware for trackers
at start
VIVE HMD:0
VIVE TRACKING:1
VIVE CONTROLLER:2
VIVE TRACKING:3
VIVE CONTROLLER:4
VIVE TRACKER:5
VIVE TRACKER:6 <----- ok
at runtime
VIVE HMD:0
VIVE TRACKING:1
VIVE CONTROLLER:2
VIVE TRACKING:3
VIVE CONTROLLER:4
VIVE TRACKER:5
VIVE CONTROLLER:6 <--- not ok - 3th controller ?
all bad, help
127 error is basically general windows error while loading any library (some dependencies are missing or has the wrong version [x86/64 conflicts as well]).
You can use Dependencies software (https://github.com/lucasg/Dependencies/releases) to find out which library is missing. More likely it has some connection with openvr_api.dll.
Yep, I can see that you are launching the engine with correct version, however, during the AppVive building process you need to link it with a correct engine version and specify correct include path from 2.6.1 SDK.
But, let's forget about this for a moment, since I've also found that some of the OpenVR users are experiencing almost the same issue that you have after recent SteamVR updates:
So the solution can be actually to change the trackers settings inside SteamVR app as described in release notes.
Please, let us know if these somehow helps.
