wxywxy.ji Posted May 16, 2011 Share Posted May 16, 2011 Clutter does not change the variables ( node references slider , Step , Density , Seed ... ) Create the position of the object is always the same? Link to comment
ulf.schroeter Posted May 16, 2011 Share Posted May 16, 2011 Clutter does not change the variables ( node references slider , Step , Density , Seed ... ) Create the position of the object is always the same? Procedural clutter object placement within clutter cells is based on some pseudo-random algorithm. The algorithme ensures same /reproduceable object placement within each cell based on user-specified density, random seed and cell size/step parameters. These are input variables. Link to comment
manguste Posted May 17, 2011 Share Posted May 17, 2011 Ulf is absolutely right :) You add a number of objects to WorldClutter, tell it how dense you want to position them - and WorldClutter randomly positions and orients objects for you. For Step, Density, Seed parameters please see the detailed description of WorldClutter. Link to comment
