eam Posted April 3, 2018 Share Posted April 3, 2018 Hello when loading data in the geotiff format in landcover in data sources there is no possibility to choose the color range to which tags should be assigned tags при загрузке данных в формате геотифф в landcover в data sources нет возможности выбора диапазона цвета на который надо назначить tags Link to comment
morbid Posted April 4, 2018 Share Posted April 4, 2018 Hello, this happens because in 2.6.1.1 one-channel sources in landcover are always interpreted as a mask. In the upcoming 2.7 release such files will be opened as indexed sources. The easiest way to use these files in 2.6.1.1 is to save them as RGB OR add alpha channel. For instance, in Global Mapper you can export file with "Make Background Pixels Transparent" checked. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
